TwinTurbo.NET: Nissan 300ZX forum - Re: is that the only thing that doesn't work?
Subject Re: is that the only thing that doesn't work?
Posted by MachinistZ on September 02, 2013 at 11:19 AM
  This message has been viewed 271 times.
In Reply To is that the only thing that doesn't work? posted by Medallion Man on September 01, 2013 at 03:23 AM
Message Yup, checked fusible links and all fuses have power to them and are not blown. Compressor does not kick on. I can put 12 volts to the clutch connector and hear it click, so the clutch is not the issue. Climate control works perfectly, otherwise, no codes, beeps when you change settings, temp sensors operating properly, blower settings work right, have performed all checks per FSM procedures and tried to chase wiring diagram, but the AC relay is not on the diagram, so it's basically useless in this case.
